I lifted the whole plane
Landing gear alignment and all of the fairings is very important to avoid reduced performance in the finished airplane. In order to do that you need to be able to put the airplane in proper position and keep it there in a very stable manner. I made two main fuselage support saw horses out of 2"x6" wood and several out of 2"x4" for wings, etc. I padded the top of all of them with permanently installed cheap carpeting. The horses give stable support but that's all. To get the airplane in proper and stable position for all of the rigging tasks I bought a 4'x8' sheet of high quality 3/4" plywood for a base for supporting the fuselage support sawhorses. I bought 4 car jacks from an auto parts store and put one under the plywood near each corner. I bought a 4' level and a small level and placed them on the canopy sills and alternately/gradulally jacked up the fuselage to get the height a level alignment I needed for what ever job I was doing and as I went I placed 4"x4", 2"x4" boards and thinner shims under the plywood for the primary support and safety (the jacks are only for the lift - they are not the sole support of the work platform). I had to make these lifts many times during the build of my RV-6A. I also put 4 caster furniture moving platforms under the plywood base several times in order to move the fuselage.
Bob Axsom
