Jabiru ( CASA )
joedallas
From THE CIVIL AVIATION SAFETY AUTHORITY
This don't sound good for Jabiru
I hope Jabiru answers how they will improve the Engine
I, [insert name] ​, PROPOSE TO TAKE A FLIGHT IN THE AIRCRAFT IDENTIFIED AS [insert registration information] (THE AIRCRAFT). I AM AWARE THAT THE CIVIL AVIATION SAFETY AUTHORITY (CASA) HAS DATA INDICATING THAT THE TYPE OF ENGINE USED IN THE AIRCRAFT HAS SUFFERED A HIGH NUMBER OF FAILURES AND RELIABILITY PROBLEMS.
​​‘I ACKNOWLEDGE THAT CASA HAS IMPOSED LIMITATIONS ON THE AIRCRAFT TO PROTECT PERSONS ON THE GROUND NOT ASSOCIATED WITH THE OPERATON OF THE AIRCRAFT, UNINFORMED PASSENGERS AND TRAINEE PILOTS. THOSE LIMITATIONS ALSO HELP PASSENGERS AND TRAINEE PILOTS TO MAKE AN INFORMED DECISION ABOUT WHETHER TO ACCEPT THE RISK OF FLIGHTS IN THE AIRCRAFT.
​​‘I NOTE CASA’S ADVICE THAT, ALTHOUGH MOST JABIRU ENGINES OPERATE NORMALLY, THERE IS AN ABNORMAL RISK THE ENGINE IN THE AIRCRAFT WILL MALFUNCTION.
​​‘I ACCEPT THE RISK OF BEING INJURED OR KILLED IN THE EVENT OF AN ENGINE MALFUNCTION DURING FLIGHT, NOTING THAT:
‘(A)​THE AIRCRAFT MUST BE FLOWN AWAY FROM PEOPLE ON THE GROUND (AND BUILDINGS), EVEN IF THAT MEANS AN EMERGENCY LANDING AT A LOCATION THAT IS LESS SAFE FOR THAT PURPOSE; AND
‘(B)​THE SAFETY OF AN EMERGENCY LANDING CANNOT BE GUARANTEED EVEN IF THERE IS A SUITABLE LANDING LOCATION.
​​‘I NOTE CASA’S ADVICE THAT I SHOULD NOT FLY IN THE AIRCRAFT IF I AM NOT PREPARED TO ACCEPT THE HEIGHTENED RISK INVOLVED.
​​‘I ACCEPT THE RISK NOTING THAT THE ENGINE MANUFACTURER IS WORKING TO IDENTIFY AND FIX THE ENGINE ISSUES AS SOON AS POSSIBLE.
​​‘I AM AWARE THAT CASA REQUIRES MY SIGNATURE ON THIS STATEMENT BEFORE THE FLIGHT MAY COMMENCE.
