LAMPSguy
OK, I read ahead, prepared, etc but I still missed a couple holes that I was NOT supposed to match drill, I thought it was just the 12 nutplate holes, but there was a sneaky rivet hole to either side that I drilled but was not supposed to.
So, now they do not line up correctly. Do I need to get more J channel and re do it? You can see in the following picture that if I just match drill and ignore it the resulting holes will be way too close.
