While riviting one of the J-Channel stiffeners to a side of my tailcone, I lost my grip on the bucking bar and denting the stiffener. It's in a spot where the skin flexes a lot from the force of the rivet gun and a corner of the bucking bar hit the stiffener when it slipped.
It's bad enough that if you're looking for it, you can feel a tiny bulge on the outside of the skin. There is also a crack in the stiffener about 1/16 from the edge and propogating to the edge. I've smoothed out the area with a little scotch-brite wheel and am going to install a section of J-Channel stiffener as a doubler over the damaged area. The skin itself, aside from the slight bulge doesn't appear to be damaged, though it is hard to tell for sure because the stiffener covers the spot. The bucking bar does not appear to have actually penetrated all the way through the stiffener.
What I'd like to know is how far on each side of the crack should I extend this doubler? I've been planning about 3 rivets worth on either side plus edge distance. Is this sufficient? Is there anything else I should be considering (aside from holding onto the bucking bar more tightly)?
Thank you,
Thank you,
