RV7Guy
Finally, my panel is lit up. I'm using the Vertical Power Primary Power System that provides power to the VP-X. There were a couple of wiring issues that Chad Jensen helped me work through. After that was done, we got the VP-X configured. Then, hit the switch and powered everything. All smoke stayed in the boxes. At this point, there are only 2 minor issues that I'm sure I will trace back to me
The equipment is as follows. 2 AFS 5500T (touch screen) EFIS's, Garmin 750, Garmin SL40, TruTrak Gemini 880, Garmin 330 remote mounted, CO Guardian 455, XM weather and radio, NavWorx ADS-B.
[/IMG]
