After Four grueling hours,And Thanks to tips from Mutha(Jon Thocker), I got the engine hung solo on the 8 today.
Tip: Use Bullets( An7 bols cut off and grinded down) to help line up and then follow bolts thru the mount tabs. DO NOT ASSume that because the bullet is short enough on one side, to go through the mounting tab and come out the other side and clear the engine case( so as to retreive it), that it will fit the oter side! Ask me how I know!:^)
Nordo
Nordo
