david.perl
I have a FT60 red cube fuel flow transducer.
Its been used for 150 hours and has worked flawlessly for that time.
This morning when priming the engine it normally gives a fuel flow reading of 3-4 ltrs / hour however the reading stayed at zero.
On starting it remained at zero for around 30 seconds then increased to give a reading of around 1/3 - 1/2 of the normal fuel flow.
the second flight of the day was exactly the same
Any suggestions?
Any suggestions?
