Hi.
We're installing the tailfeathers now, and have run into a possible problem regarding how high the VS shall be installed.
The exact height from the lower hinge and to the longeron is given on the drawing, (7 and 11/32 if memory serves?) but that seems alittle too low?
For example will the lower fwd end of the VS end up alittle BELOW the aft skin just in front of it?
On my first RV, which was built by a US A/P, the lower fwd end of the VS ended up AT THE SAME LEVEL as the aft skin just in front of it.
The lower part of the VS on that plane had about 1/2 inch clearance to the tailwheel bracket for the TW.
By looking at the drawing, it seems like the lower part of the VS schould ALMOST rest on the mentioned tailbracket.
Schould I stick to the drawing and build on or adjust the VS alittle upward?
Here's a couple of pics of the clamped VS with the height exactly according to the drawing:
![](/proxy.php?image=http%3A%2F%2Fimg40.imageshack.us%2Fimg40%2F8330%2Fvslowfwdpart.jpg&hash=16366bf3bbfa2a1db759135f7834c726)
![](/proxy.php?image=http%3A%2F%2Fimg21.imageshack.us%2Fimg21%2F8269%2Fvslowerpart.jpg&hash=efd0913bf24a61a41296f8e0a8bee74c)
