BJohnson
I am connecting the elevator Dynon servo to the Skyview harness and have mounted at DB9 connector without the back shell below the servo. The connector halves are held togehter with tie wraps, and a third, larger tie wrap goes around the body of the connector and around an Adel clamp mounted to the structure. See picture. I'm still in the education mode of the wiring portion, so is this a secure enough mounting? Ignore another tie wrap passing in front of the connector.
Can I leave the back shells off?
Can I tie them together with two small tie wraps?
Is a single tie wrap around the central portion of the shell and an adel clamp secure enough?
I still have easy access to this area. Any help here is appreciated.
Brice
![p1060693lr.jpg](/proxy.php?image=http%3A%2F%2Fimg293.imageshack.us%2Fimg293%2F1357%2Fp1060693lr.jpg&hash=9cb71390fc8dee4df88c1ca9f74cde43)
Brice
