alpinelakespilot2000
Finally got my wing sweep to 0 degrees, my incidence (measured with the block) to 0.0 degrees, and am preparing to drill the rear spars. I've measured about the best I can 5/8" around all pieces. What I'm left with is what you see below inside the center box. It's about 1/8" wide by 1/4" tall. If I drill anywhere within this box I should have adequate edge distance all around.
![](/proxy.php?image=http%3A%2F%2Fimg252.imageshack.us%2Fimg252%2F5981%2F15151811ut2.jpg&hash=66bd4681addef1a1fa106346ff1e45e5)
Is this typical of how much leeway others have had in drilling the rear spar? Van's doesn't leave much extra for error, that's for sure! Just looking for confirmation before I do the deed! Thanks.
