Paul 5r4
Hi Friends,
As many of you know, the Dynon D-100 and D120 require modification of the ribs the panel is mounted to. I've done that and would like to ask if you guys ahead of me in the build think my mod will interfere with the... I think it's called the "Canopy Brace" which attaches under the tip up above the panel. If you think there will be interference, I'm thinking I'd rather cut a little slot in the tip up canopy brace rather than cut an angle on the forward end of theses angle which I've added on. Thanks in advance.
![28lyqlj.jpg](/proxy.php?image=http%3A%2F%2Fi40.tinypic.com%2F28lyqlj.jpg&hash=d83ca9b0552cbb58668e194a6e16627d)
