We are currently working on the switch list for the new RV-3, and I am beginning to think that I am ready to get rid of the alternator field switch. I figure that, at the very least, the idea should be able to generate some ?interesting? discussion?![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here?s the deal. I am quite happy with the ND internally regulated alternators that were, for years, supplied in the FWF kits, and are easily obtained at most auto parts stores. I like the fact that they can be picked up easily in an emergency away from home, and quite frankly, I have never had an airplane alternator (certified or not) last as long ? as long as you operate them the way they were designed. This means that you don?t want to switch them on or off while they are spinning. (I didn?t come up with this little gem of wisdom ? search the archives for alternator posts by GMCJETPILOT). This argument makes sense when you consider the sudden load that can hit the diode/regulator pack if you switch it while the rotor is going full tilt. In automotive use, they don?t have ?pilot? controlled switches, after all.
When I built my -8, I put in a Cessna split master, like many folks did. I brought the alternator on line after engine start. That alternator lasted a few hundred hours before the VR started to ?wander? a bit. I replaced it with a rebuilt unit, decided never to switch it while turning and that was about 800 operational hours ago. We have had similar experience with Louise?s RV-6. The bottom line is that the way the field power is wired is with a circuit breaker and switch in series. If the ONLY time you?re going to switch the alternator off is in a failure condition, then you could easily do that by pulling the breaker. The added benefit is that you are less likely to accidently turn it off without a switch there in a row with the other normally operated switches.
So in summary, I see two good reasons to delete the switch - less chance of accidental activation and the saving of critical panel space (the -3 is a small cockpit). I can?t see any real downside to it.
Relevant thoughts? And no, I am not planning on going with a B&C or PP alternator this time around?.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Paul
Paul
