FORANE
It seems there are differing opinions on whether the so called stealth mode of the ADS600-EXP is really stealth.
From the Navworx site:
AutoStealth(tm) Mode:
The UAT technology is the only ADS-B equipment that will allow for privacy. Normally, ADS-B devices transmit the aircrafts ICAO number, a unique code that is assigned by the FAA to each aircraft. When flying VFR however, there is no need to let the FAA know who you are. The ADS600-EXP randomizes the ICAO whenever the squawk code is set to 1200. In addition, the N-Number of the aircraft configured is changed to "N0", an unassigned N-Number.
So, why have I heard some say and read some posts which state this is not the case?
