Working on SB 67, which requires disconnecting the cables to the stab to remove it and the balance arm.
It would seem to simplify the steps by NOT bothering to loosen the cable tension barrels before disconnecting the cables at the stabilator horns.
It's only 40 lbs of tension or so....
Yes I'm lazy.....any reason why not just disconnect/reconnect at the stabilator horns?
I do have a cable tension meter, so if necessary (eg if I loosen at the barrels before disconnecting at the horns)...but looking to simplify.
Anyone ever done it that way?
