Here is what happened to me. I messed up the rivet hole for a 470AD4 rivet that attaches HS405, HS702 and HS714 by drilling it out twice, all because I want to have a better looking rivet. The hole is enlarged and I have to drill it to next size rivet hole using #21 drill. I wanted to put a 470AD5 rivet there, but none is available at the moment. I found the 6 BSPQ-5-4 pop rivets that came with the empennage kit. Really 4 is needed, so I have 2 spare. I checked the shear strength of BSPQ-5 rivet to be 525 lbs (http://www.avdel-global.com/fileadm...ial/Breakstem/Q_Rivet_BSPQ_BSLQ_BSCQ_inch.pdf), while the shear strength of 470AD4 is about 360 lbs. So I went ahead using the BSPQ-5 rivet to replace the 470AD4. No long after, I found on the bag that packs the BSPQ-5 rivet reads "N Rivet BSPQ-5-4", hmmm...... I then checked the shear strength of BS serious of N rivet, it's about 260 lbs, lower than the 360 lbs that 470AD4 will give. Shouldn't be BSPQ-5 a Q rivet because the fourth letter is Q? Also, one of the difference between N and Q rivets is that N rivet will have a hollow rivet (the steel shank will be pulled out after popping). My I checked BSPQ-5 after popping and it has the steel shank there. Anyone can help to clarify?
