WingedFrog
As I am close to buy an iPad for use in my RV-12, I would like to know from current users what amount of memory is necessary just to run the standard aviation Apps.
32 or 64 GB is not really the issue with the Ipad. The big issue is how to actually see it in the cockpit. If the sun is bright you will not be able to see the display at all with Sunglasses on. You will have to tip them up or remove them each time you want to see the Ipad. With glasses off you now can marginally read the display. For that reason I have so far stuck to borrowing my wife's Ipad when going cross country. If the Ipad 3 has a sunlight readable display then I will be the first in line to purchase one.
George
George
I use the Samsung 10.1 tablet with Aviloution... 16 GB plenty of room for several apps and 4.95 per mo for all updates, hi, lo, approach and much more. Great moving map display etc... Check it out...
One possible issue (and as a slight sidebar to the topic). I was just goofing around with the IPAD a couple of days ago (doing a crossword puzzle) and for no apparent reason, it just froze. Nothing, no combination of keys or buttons budged the display.
Remember, with the Ipad when you close a program it is still running in the background. If you have enough programs open, you may run into some performance issues. The way you close the programs is to click the home button twice. This brings all the open programs up at the bottom of the screen with an "X" in the upper left hand corner of the icon. Click on the "X" and close the program. When you are done closing them all out, click the home button once and that brings you back to the main screen. I always close all the programs I am not using before I climb in to the plane.
If your Ipad locks up, try holding the off switch and the home button together until it brings up the shut down slide. Worth a try anyway...
Jon D.
He skipped a step. Double click the home button, all the running apps pop up at the bottom, then touch one of them and hold it for more than a second or so and they all get a close symbol (although not an X, it's a "do not enter" symbol). Touch the close on each running app you want killed and then touch anywhere else (or the home button) and you get out of the app killing mode.
I was just going from memory....didn't have my Ipad with me at the time.
Jon D.
Jon D.
Jon D writes....
I appreciate the tip; and actually I did try that, and...nada. The tips on closing open aps by you and Chris F look especially valuable - - Thanks muchly!
If all they do with the Ipad3 is increase the resolution and go with a IPS screen, don't expect better sunlight performance.
This did little to nothing for the IPhone 4.
Those that claim they can read and actually use the iPad in bright sun easily must be kidding themselves.
I have tried at lead six different matte protectors....cheap all the way to expensive. They help and hurt. None of them are miracle workers.
Your pic is not an example of real life use and looks to be aligned to favor the perfect angle for this setup and lighting.
People need to stop kidding themselves. The IPAD screen stinks in the sun and there is nothing you can do to change that.
Is it usable in the typical RV cockpit? Marginally at best with all the tricks to make it readable. (hold it at the right angle, screen protector, Koger sunshade, etc.)
I was one that took the advice of some on this forum that said the IPAD was fine in the sun. Bought one and now I am really disappointed in how readable it is in the RV. I don't want others to be just as disappointed!
The IPAD is great in all other aspects though. I use it everyday. If it were not for the pitiful sunlight readability, I would say it is close to perfect.
