Don
Is anyone running the ECI IOX-340 Stroker in their 9 - or planning to do so? If so, what prop are you using and how do you like it? My thoughts have been running toward a CS. I'm also curious what cowling you ordered from Vans as I'm hoping to order mine tomorrow (I'm sure Vans can help me get the right one).
Please no flames or pointing out that you wouldn't do this (because no one is asking you to use this engine). I'm looking for folks with experience with this engine and airframe combination. I understand that this engine is rated at 185 hp and Van's max recommendation is 160 hp and I've read a number of articles on flutter and in particular Van's own article on the limit. It appears to me that the problem isn't the extra horses, its how the extra horses used. The airframe has limits that I don't intend to exceed deliberately and with the GRT EFIS I have purchased I can install an alarm to catch an unintentional exceedence of the true airspeed. No matter what hardware I have I can placard the cruise limits.
Compared to the O-320, the OX-340, the OX-360 and the IOX-360, the IOX-340 Stroker engine has the best fuel economy and the weight penalty is 10lbs compared to an O-320. With fuel running around $4/gal even with conservative assumptions the savings are real. Add to that the smoother running operation and more even CHTs and the choice seems even better. It appears to me that this would be a fine and fun engine for the 9, provided one is inclined to understand and live within the limits of both the engine and airframe, which I am inclined to do.
Don
Don
