Ok, here is something that was pointed out to me this summer. An acquaintance of mine blew a jug on his Bonanza. he was able to return to his airport on partial power but lost a lot of oil. Based on his time of flight he was able to calculate that he was losing a quart every five minutes. In some parts of this country an extra five minutes of flight could make all the difference.
I did an experiment this summer by using 8 quarts and then 9 quarts. The blow by was the same. Each installation will be different but I would recommend adding as much as you can for safety sake alone, not to mention that one more quart dilutes contaminates that much more and also provided a greater heat sink for cooling. Experiment with your plane, start off with 8 quarts, fly it for a while, clean the belly and then add a quart and see what happens.
