The K means angle valve cylinders vice parallel. As I understand, the K is heavier and larger...and was told not an acceptable choice for the -10. - Jim
The D4A5 is a parallel valve engine and the K series engines are angle valve and 300HP.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
