Sylvainsting
Active Member
Hello,
I'am using an Aerosport Power IO375 Engine (195 HP) on my RV7 and a Skyview D1000 system. I have some difficulties in the ROP/Pk/LOP procedure.
When I mix from ROP to LOP, at one moment Skyview shows the Peak moment, but it is not the real Peak and my EGT temperatures continues to grow up.
There is a shifting between the "calculated" Peak from the Dynon and the real Peak.
The Dynon instructions seems to say that it is the power engine value indicated in the engine information page which can cause this offset.
Did somebody experiment the same and what is the good setting to have the wright peak information ? I tried 180, 185, 190 and 195 HP but I never saw the Peak at the wright place.
In advance thank you
Sylvain
Sylvain
