I currently have a narrow deck engine. What would need to change if I installed a wide deck?
F F1 Rocket Well Known Member Dec 15, 2021 #1 I currently have a narrow deck engine. What would need to change if I installed a wide deck?
F Flybipe Well Known Member Dec 15, 2021 #2 Governor Wide decks use a different gear ratio than a narrow deck engine. Weight and balance, as well since the WD's are heavier. And possibly some baffling if the baffling is already trimmed, as the WD cylinders are slightly different. Last edited: Dec 15, 2021
