w1curtis
I've posted this to the Matronics site so if you have seen it and replied there not need to reply again. I have about nine builders already interested, more should lower the price.
RV-10 builders nearing Firewall Forward or engine planning stage. Having not ordered the Firewall Forward kit yet and just planning ahead, I've looked at the plans and determined the following hoses are required for the IO-540 installation:
VA-119 IE VMP HOSE (AN4, 21.5, AIR) $ 34.60
VA-102 FUEL PRES. HOSE (AN4, 15.5, FUEL) $ 58.20
VA-133 OIL PRESS HOSE (AN4, 27.25, OIL) $ 69.00
VA-138 FUEL SUPPLY HOSE (AN6, 14.0, FUEL) $ 69.65
VA-189 FUEL LINE IO-540 (AN6, 25.5, FUEL) $153.45
VA-135 OIL COOLER HOSE (AN8, 16.5, OIL) $ 66.85
VA-190 OIL COOLER HOSE (AN8, 27.0, OIL) $ 95.65
I'm not sure but I think the only Van's hose that is Teflon with the integral firesleeve are the VA-138 and VA-189 hoses. I requested a quote from Aircraft Hose (http://www.aircrafthose.com) for the above hoses ALL Teflon with integral firesleeve except the (VA-119) MAP Hose. They came back with and initial price of $491 for the set. The Van's price for the set of hoses (not all Teflon with integral firesleeve) is about $545. I've asked them if they could offer a greater discount if we could arrange a group buy. I haven't heard back from them yet but wanted to get you thinking.
Here are the specifics.
Stratoflex Integral Firesleeve Hoses for RV-10
111-4 hose with a 300-4D fitting 21.50" Long (111001-4CR0214) (IO-540 Man Press.)
124-4J hose with a 524-4CR fitting 15.50" Long (124J001-4CR0154) (IO-540 Fuel Press.)
124-4J hose with a 524-4CR fitting 27.25" Long (124J001-4CR0272) (IO-540 Oil Press.)
124-6J hose with a 524-6CR fitting 14.00" Long (124J001-6CR0140) (IO-540 Fuel Supply)
124-6J hose with a 524-6CR fitting 25.50" Long (124J001-6CR0254) (IO-540 Fuel Line)
124-8J hose with a 524-8CR fitting 16.50" Long (124J001-8CR0164) (Oil cooler)
124-8J hose with a 524-8CR fitting 27.00" Long (124J001-8CR0270) (Oil cooler)
Hose with Integral firesleeve
Hose with external firesleeve
![pic1248j.jpg](/proxy.php?image=http%3A%2F%2Fwww.aircrafthose.com%2Fimages%2Fpic1248j.jpg&hash=6fd9178640815d73b05510fbbdceb4a6)
![pic2650c.jpg](/proxy.php?image=http%3A%2F%2Fwww.aircrafthose.com%2Fimages%2Fpic2650c.jpg&hash=bd1388b295a243c78c9f7d8d1dbf3fa8)
