on the engine driven fuel pump there is a threaded opening on the side that is mid way on the side of the housing. On the other IO-540s I've looked at, they have also left the port open. What's the purpose of it?? Inquiring minds want to know! Thanks, Dan
It also needs a hose on it to get the fuel out of the cowl in case a diaphragm ruptures. Most setups have a 1/4" rubber fuel hose sticking out the bottom cowl, usually near the firewall away from the exhaust.
