IO-360 Engine Gauge limits for EFIS
dhall_polo
Quick start, anyone?
Looking for a compiled list of values for programming the limits on EFIS gauges for parallel IO-360? (Mine happens to be IO-360-B1B, CS prop) I have read the engine manual, just figure this is something that's been done 1000 times by now.
[min, low red, low yellow, high yellow, high red, max]
for each gauge
[map, rpm, oil psi, fuel psi, fuel flow, oil temp, volt, bus, cht, egt]
My settings
for each gauge
On my MGL Odyssey and Enigma I have currently set the following.
  • Map, 32" max display, no red or green sections. :)
  • rpm 2700 redline, warning at 2650. High cruise at 2500
  • fuel psi, 60 max, 0 min, warn at 12, alarm at 8, high alarm at 50.
  • fuel flow (don't have one) (yet)
  • oil temp. Redline 250, alarm at 225, warn at 220, yellow at below 100
  • oil pressure. Redline 110, warn low at 40, alarm low at 25, green from 40 to 90
  • voltage. Too high at 15. Too low at 11.5
  • No ammeter (yet)
  • cht. Redlined at 450. Warn at 400. Alarm at 425
  • egt. Redlined at 1550. Warn at 1450 Alarm at 1500
There are just my numbers. They will be tweaked as needed during the upcoming test flights. My engine runs pretty cool except for oil temps which were a bit high, but may improve since the rebuild.
IO360-A1B6, constant speed.
