I am building an RV-9. I purchased an IO-320 Twin Comanche motor and I am trying to attach the motor to the engine mount. However the rear case of the engine where the lord mounts rest has a flange which will not let the lord mount sit at the correct angle. I was hoping that someone has run into this problem and has a fix or solution for it.
