I'm in the planning stage for an RV-7A and would like to know pros and cons of the 180 hp injected vs carborated engine. I've heard good things and bad about both depending who I talk to. Just need more information to make my decision for me.
Thank you.
He implied to me that there were extra fuel tubing that had to be installed in the floorboard in front of the seats. Would this be fuel pumps and lines that are not required with the carb?
I have several hours behind both types and each performed well. The only thing that may swing me to the carburated type might be the situation with 100LL. An A&P told me that it would be much easier to convert a carburated engine over to automotive fuel than an injected. I'm not sure how much more of a challenge it would be to convert the injected engines than it would the carburated.
I will research this point before purchasing my engine. I like the performance of the IO but my pocketbook prefers the O.
I was also given the impression from someone who has helped build many RV's, that the FI was more difficult to install. He implied to me that there were extra fuel tubing that had to be installed in the floorboard in front of the seats. Would this be fuel pumps and lines that are not required with the carb?
Ned
Planning RV-7A
Ned:
The IO electric pump and filter are in the cockpit and are more difficult to build and service. The carb has a single fuel line that goes from the fuel selector to the facet pump on the F/W. The IO filter/pump assembly has a menagerie of tubing that reminds me of a trumpet stuck down there. Modifying the center cover and installing the filter/pump assembly may take you several extra evenings over the carb. Forward of the F/W is not that much more difficult to build. There is an extra fuel hose on the IO, 2 if you use a return line. Also you may need to add a sniffle valve and drain line.
All together, it may add a full weekend to your build time, more weight and cost and then there are the benefits......
Jekyll
And some of the benefits you think would be what?......
I hate hanging chads!
So what's the cost difference in the installation of IO over Carb?
Ned
All the benefits mentioned by previous posters.
I can't tell you why Van's designed the filter/pump the way they did so I won't consult the tea leaves. I can only comment on the implications to the builder.
Compare Fire Wall Forward kit prices and engine prices on the Vans web site to determine the price delta. I don't recall if the filter/pump is part of the FWF kit or if you must buy it seperately.
Jekyll
