Hi Jake...
Others will have their opinions... but here are mine!
180HP is ideal for an RV-8... more will rarely be used, and must be balanced against any extra weight up front. A possible exception is the ability to cruise faster at high altitude where a higher power engine will give you more speed - this factor not so relevant for those of us in the UK. Prop is clearly as big a factor here (FP? C/S? Metal? Composite) - if not more so.
Not many fit full inverted oil, but many fit a flop tube. I would reverse that decision - there is little need for a flop tube unless you have inverted oil. Inverted Oil will add weight / cost / complexity up front, and an element of risk, especially if it is not maintained. So ask yourself if you really want to do more than short duration inverted?
Fuel Boost pump - not sure what you mean by "standard"? It is not supplied in the "kit", but are via the Van's catalogue. There are alternatives available.
CG is a big consideration in the RV-8. Going for a big engine, full inverted system and a metal C/S prop will make solo aeros much less fun
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
A small engine, wood FP prop and no inverted with a heavy pax will put you out of rear CG limit for aeros. So take CG into account with what you fit, and some decisions during the build e.g. battery.
All of the above are re the RV-8. From your username (BergRV8
A) you might be looking at a completely different type about which I know nothing
Andy
RV-8 G-HILZ
