Curious to hear if anyone has installed the internal rudder stops that has been used in other RV models? I am considering using them and would be great if there is any feed back from others.
I have used one on my RV-7A for the last 6 years with zero issues. It is made of delrin. Can't remember where I purchased it. Only drawback is using the original rudder stops with a hole drilled in it to "pin" the rudder for a gust lock. I use an in the cockpit gustlock so it has not been an issue for me.
