stevepattinson
I'm New Here
I have a 3 stage flap actuator and every now and again my flaps will not work. Dont know whether its the flap switch or motor. Has anyone had similar problems??
stevepattinson said:I have a 3 stage flap actuator and every now and again my flaps will not work. Dont know whether its the flap switch or motor. Has anyone had similar problems??
tadsargent said:You can also take 600 grit sandpaper and lightly sand the place where the brushes meet the motor to get it to shine again if needed but do this carefully. Luck
Tad "Stripes" Sargent
7A 180 hours
My flap motor in RV-7A stopped working today March 2021. It has only 86 TT. I opened it and it is full of black stuff. I see Van's writeup about cleaning it. Is it worth it or should I buy a new Van's motor or a new other flap motor. I don't want to remove and clean this every 100 hours or at every annual.
Have those of you who have cleaned it had recurring problems or does one good cleaning solve it?
Does the PH Aviation Services similar flap motor have issues?
thanks for your knowledge.
