Thomas,
To prime or not to prime - the eternal question! This is a highly individual decision - you can find arguments from one end of the spectrum to the other if you do a search. After much consideration, I took the middle road. A major factor in my decision was, I don't live near salt water.
I am priming all the stuff Van's says should be primed, like bar stock, angle stock, anything that is not alclad. In addition, I am priming all internal structural parts, because they get pretty roughed up during the deburring process, and a lot of the alclad gets compromised. I am NOT priming the inside of skins as a cost and weight saving measure. (I own a 1969 Arrow that was not primed or corrosion treated, and it still looks great on the inside.)
I am using NAPA 7220 self etching primer. It is relatively cheap (ask them for a discount when you buy it six cans at a time), easy to use, and is available locally. Many other builders are using it. Probably not as good as a two part primer, but way easier to handle.
OK, that's my compromise solution to the priming issue. Just my humble opinion. Check back with me in 50 years and I'll tell you if I have any corrosion!
John
