Intercom problem ic-a210
don rv-7
I'm New Here
Intercom seems to be very sensitive. Squelch all the way up won't close the mics. Anyone herd of a fix?
Hi have you adjusted the squelch for both mikes. mine are both set at max squelch ( minimum sensitivity ) and still get unwanted open mike if air from vents of canopy gap hits the microphone
I think the dynamic range of the squelch was increased in one of the firmware updates. I had the same problem early on but a software upgrade and Mic Muffs cured it for me.
