RVG8tor
I am just starting my RV-8A QB fuselage. One of the first steps is to install the main gear legs insert a undersized bolt to line up the parts (leg and mount) and then ream the mounting hole to .311. Well the legs are not close to going into the gear mounts. I know the powder coating can cause some interference, I have lightly sanded with some 800 grit paper the edges but still no luck.
Anyone have any tips on how to clean up the gear mount holes for a nice tight fit. On my QB the weld mounts are already installed so I can't take them to a bench. I do plan to use some NAS closer tolerance bolts since I have read where some have had gear loosen up in the first few hundred hours. Thank you in advance for any help.
Cheers
Cheers
