I was trying to install my de luxe quadrant and it was all a struggle as the bolts didn't align properly. Eventually I disassembled the whole thing and the photos show the back plate clecoed in place on the F864 using the lower holes - as you should be able to see the upper holes misalign by maybe 1/8". Is this a common problem? I could enlarge or elongate the existing holes so that the bolts will sit squarely, but then it'll be a kinda loose and sloppy fit which I'm not too keen on. If I had a bit of sheet the right size and thickness I could remake the back plate and make the holes all line up - is that going to be the best thing to do? Or is the problem the F864?
Chris
<a href="http://img98.imageshack.us/my.php?image=rv8jan08022bo2.jpg" target="_blank"><img src="http://img98.imageshack.us/img98/9084/rv8jan08022bo2.th.jpg" border="0"/></a>
Chris
