Steve Sampson
Hi -4 builders! I wouldn't mind a bit of help. I have been working on the engine cowls over the last few days. I have run into two problems:
i) in the build book it tells you 'trim the lower edge of the upper cowl to the scribe line' or something similar. I didnt get a scribe line, so I have little idea how much to take off. Anyone else have this problem? How much did you actually end up taking off. It looks to me as though 0.5" in the middle and a bit less at the ends might be right, and give me a straight edge, but I know I cant put it back once its removed. In total, between the upper and lower cowl, I have to remove about 5/8" at the spinner and 1 1/8th at the firewall to get the bottom of the lower cowl to the right height.
ii) if you look at the third picture here, you can see the air intake is considerably offset to the right in the picture. Is this normal? (The uncut cowls are just taped one above each other here.)
I would welcome all the input I can get.
