A little tip: When installing the static port rivets (Page 10-08), I would not suggest using a hammer to pound out the unneeded center steel stem - its too easy to dent the side skin. Instead, drill a @ 3/16" hole in a small (@ 1" x 1") block of wood. Put the block on the inside of the side skin with the hole over the static port shop head. Then cut a @ 1/2" long piece of used LP-4 rivet stem (you can probably find one lying around
), square-up the ends, and put it in the exterior static port hole. Use a ratching bar clamp (or C-clamp) to squeeze the unneeded center steel stem out into the block. No trauma to the side skin! Keep on squeez'in!
