mikeangiulo
Active Member
I'm installing the ground adjustable rudder pedals in my QB8. There are a couple of rivets that I have to drill out and replace with flush rivets. The problem that I'm having is that the rudder pedal anchor angles seem to line up almost exactly over these holes - the plans show them being inboard of each of the existing holes and I don't know whether I'm just supposed to rivet the pedal rails to the holes that are already there.
I know this would be easier to understand with a picture but if you did this step this might be enough to jog your memory
