LettersFromFlyoverCountry
The plans for installing the nose wheel have several dimensions (for example, the center of the axle nut is 5 1/2" on the floor) and the notation that these are to be checked with the longerons level.
Do folks usually check this with the engine on or off. My engine is currently not installed, and just futzing with it today I couldn't get the longerons level (got it to .5 degrees) because I couldn't lift the tail anymore because of the nosewheel.
My measurement such as it is is the center of the axle bolt is at 5 7/16." I currently have 25 psi in the wheel and I know it calls for 35 (which would, not doubt, give me my 5 1/2" but I still wouldn't have level longerons).
Anyway, what do you folks usually do here?
