LettersFromFlyoverCountry
I'm learning -- very, very slowly -- the ins and outs of magnetos. As you know if you've followed another thread, I had an RPM problem on the TMX IO-360 and it was suggested that the mag timing was off.
A pal, using the buzz box, set the mag timing, but when we tried to fire it up on Wednesday night, the prop whirred a time or two, then hung up briefly -- apparently this is a sign of a kickback about to happen. I had whirred it a few times with the mag off with no problem.
So, it was suggested, the mag needed to be internally timed. The mag was off the engine once -- when I was trying to get access to put the AN fitting on the oil port for the cooler lines -- and I probably wasn't very careful putting it back on ... or at least as careful as I needed to be.
What's odd is that I don't remember this occurring on first start last September and it only seems to have been a problem in the few times I've started the engine this spring. (It sat all winter)
Anyway, I took the mag off yesterday and took the distributor cap off and played around a little bit. I don't have a timing pin -- I've ordered one -- but just using an LP-4 pop rivet, I turned the rotor until it dropped in. This is the orientation if got on the impulse coupling assembly. It does not appear to be anywhere near the point at which the impulse coupling begins to wind and I was under the assumption that the timing pin assures that it is.
Another question: I notice in this excellent article it says that the mag should be reinstalled like so:
First, remove the top spark plugs from all of the cylinders. Then, turn the propeller in the normal direction of rotation with your thumb over the spark plug hole on the No. 1 cylinder. When the air pressure on the No. 1 cylinder starts to build up and tries to blow your thumb off the hole, slowly continue to turn the prop until the timing mark listed on the engine data plate lines up exactly with the split line on the top of the crankcase for Lycoming engines or the split line on the bottom of the crankcase for Continental engines. Typically, Lycoming engine timing marks are located on the starter ring gear and Continental engine timing marks are located on the propeller flange.
I've been led to believe the proper spot is when the 25 degree mark on the flange is lined up with the reference hole on the starter. Which is it?
Any additional education you can contribute would be most appreciated.
![2012-05-12_17-10-16_581.jpg](/proxy.php?image=http%3A%2F%2F3.bp.blogspot.com%2F-9oO36OwkPTA%2FT6-7_DdtTXI%2FAAAAAAAAFRk%2FKb6fX1ooVAg%2Fs400%2F2012-05-12_17-10-16_581.jpg&hash=00d56ec64cddc2c576609e465cb110fc)
