I am stumped by something that should be easy. I just installed the muffler and then tried to install the bottom cowl to check alignment of the exhaust pipe in the cowl opening. I cannot figure a way to tilt/angle the cowl to get it under the end of the pipe and up into place. Perhaps I will need to trim the pipe a bit but I hesitate to do that until the cowl is in place so that I can measure the minimum distance. It does not look like it is that long anyway. What is the trick for this?
Jeff
Jeff
