Installing Andair Gascolator?
Rick_A
Trying to plan ahead while I still have good access to both sides of the FW. I plan to use the Andair Gascolator. I called Vans about using the VA-161 gascolator doubler with the andair gascolator. I was told VA-161 was drilled for the Vans gascolator and I might be better off fabricating my own. I'm curious about what other people have used for the doubler and mounting bracket.
Rick,
The exact mounting Vans suggests works well with the Andair as well if you use angle like I did. Check it out.
http://www.jeffsrv-7a.com/ENGINE/06-01-14.htm
-Jeff
