Phil
I know this is simple and I'm making it way more complex than I should, but I'd like to get some other opinions before I do something dumb.
I have the standard MT prop that Vans sells for the IO-540 and one of two things are going on.
1) The installation documentation isn't that detailed; or
2) It's very detailed and I just can't read German well enough to tell.
On my engine, I have 4 male lugs and 2 female lugs. On my prop, I have 5 female lugs and 1 male lug.
I get the whole concept the male/female and proper clocking of the prop.
In the case of these two photos, the lug at 9 o'clock position would have an air gap around the bolt because the engine lug is female and so is the prop hub. It seems to me that I should have a male lug on the engine to fit into that recess on the prop hub.
1) Is that normal?
2) Best I can tell from the documentation, these should be torqued 63-66 ft/lbs. Is that also right?
Phil
Here's a photo of the engine:
1) Is that normal?
Phil
