Installing 61510 Plug for CS Conversion
ten4teg
I am in the process of converting to a CS prop. I am ready to install the 61510 plug in the crankshaft behind the oil return line. I made a tool to install it, but wonder if I should put and sealer on it. Should it go in dry or with some sealer? Appreciate the help. Contact [email protected] Thanks
Dry press fit. The most worry is damage to the oil pickup tube, but if you made a tool that goes around it when you set the plug you will be fine.
Be careful,
Carl
