Ok it's confessional time. My first major bone head mistake (that I feel obliged to confess). It happened during the tail cone buildup. I hung all three of the ribs/frames to the J channels on the bottom tail skins clecoed then hung the lower side skins and clecoed. All looked good and so I proceeded to rivet the lower skins together and then the skins to the frames. I then riveted the side skins to the lower skins but did not rivet them yet to the frames - just clecoed. When I flipped over the section to my horror I realized that the frame in the front (the largest one) was in backwards
I'm not exactly sure how to get it out of there. I was going to drill out the bottom rivets but the frame will still be hooked into the J-channels of the bottom and side skins (2 on each side). I was thinking maybe I could just disassemble the frame but I'm not sure if that would give me mobility to get it out. Is the slot in the frame that fits into the J channel structurally necessary. I was thinking of bending or even cutting it. Any ideas ?
