Pics
Hi again.
Here's pics of my installation.
After the pics was taken, I sealed every firesleeve edge with high temp RTV (red).
The firesleeve material is bought fram Vans and ACS and are different sizes.
The hose is fastened with a hoseclamp where it passes (above) the induction tube to cyl # 2, otherwise unsupported.
Heatshields are used on both exhaust tubes.
This setup was the closest one to the AFS instruction manual I was able to.
In the last pic, you'll see my modified mix bracket. Thiis mod makes the mixarm go a more straight arm into the mix lever.
I've only 27 hours on the plane by now, but so far the setup seems to work well.
If you want more pics, I can send them to you directly. Just send me an e-mail.
Good luck.
