dhall_polo
Van's directions are ok, but a few pics and words might save anyone about to do this some head scratching.
I marked 3 points on the leading edge of the leg fairing and hung a plumb bob from each to mark the distance from the centerline. I also noted the height of each point above the ground. I then marked those 3 points on a board which was clamped to a shop stool. Each point on the board is the same distance from centerline and height above ground as the points I marked on the fairing. I put a staple at each point and ran string to it's corresponding point on the leg. It was necessary to tape the string on the leading edge to keep the string from slipping down. Now each string is pointing straight back, parallel to centerline.
Using a ruler, I measured the distance between strings and tweaked the trailing edge of the fairing to split the difference. (this shot is from the ground looking up the leg to the cowling.) Now it's safe to clamp in place and inject foam.
![DSCN0453.sized.jpg](/proxy.php?image=http%3A%2F%2Fdonka.net%2Falbums%2Fwrapup%2FDSCN0453.sized.jpg&hash=aa738d18391efcad230fb3d6835aeba0)
![DSCN0454.sized.jpg](/proxy.php?image=http%3A%2F%2Fdonka.net%2Falbums%2Fwrapup%2FDSCN0454.sized.jpg&hash=c768104b66a39ca1fb645b186a7eb2ea)
