CharlieWaffles
I am working on finishing my door interiors and need to find a way to make a good inspection cover so I can access the working end of the exterior lock. I previously cut my hole and added some flanges to the inside of the door to support the panel. I cut a piece of fiberglass scrap that was slightly undersized from the hole and then taped it and the surrounding opening and pressed in some West 407 lightweight filler. I let it flash and popped it off. It helped contour the door to the hole a little better, but it's still not a good tight match up to the hole.
So I'm wondering if there is a better way to go about making inspection panels for something like this or if this is as good as it gets and I should just look at doing some upholstery or other process over the area.
![WP_001173.jpg](/proxy.php?image=http%3A%2F%2Fi1079.photobucket.com%2Falbums%2Fw513%2Fcheapguy69%2FWP_001173.jpg&hash=fa6ab955979afa7c7ceb60ca829c1225)
![WP_001174.jpg](/proxy.php?image=http%3A%2F%2Fi1079.photobucket.com%2Falbums%2Fw513%2Fcheapguy69%2FWP_001174.jpg&hash=81f51d9a321f61ab58327ecb8db9f157)
![WP_001175.jpg](/proxy.php?image=http%3A%2F%2Fi1079.photobucket.com%2Falbums%2Fw513%2Fcheapguy69%2FWP_001175.jpg&hash=921de4183e752ddebf07c62045622bec)
![WP_001176.jpg](/proxy.php?image=http%3A%2F%2Fi1079.photobucket.com%2Falbums%2Fw513%2Fcheapguy69%2FWP_001176.jpg&hash=0de24ea802c6df402c7b988274885b68)
