Now that I have a few flights on N908BL I thought I'd give some notes. At this point, I have made no real attempts at top speed or even max cruise. I haven't had it above 4500 feet. I have something over 3 hours on it.
For those of you not familiar with it, it has an O-320 (160hp) with 888 hrs TTSN and a Catto 3 blade. The prop was built for an E-mag which is still in the box. It weighed in at 1054 painted with interior. I have pulled a few things out (right stick, seat and interior) and figure it is about 1045 as it sits.
Takeoffs are really quick. It does take a good bit of right rudder. Climb seems most comfortable at around 100 and it will hold 2000 fpm at that. This is while light as I haven't had over 1/2 fuel. I have NO temp problems!! Today at 70 degrees I pulled it back to 85 in climb and stayed under 400 CHT's. #3 is warmest, about 10-15 degrees above the rest.
The Trio AP worked right out of the box. Still trying to get the alt hold to do the same. Have an XCOM760 and it took a few tries to get the intercom squelch right. Seems to work very well now. Love the D10A. It's AOA is cool, although it took a couple of tries to get it to work. Somebody didn't push all the right buttons. Wonder who. . .
Trim is powerful (I have electric) and too quick at cruise. Gotta retrim for a T&G also. Right wing is heavy by about 6 gallons. I believe it is aileron rigging as when I hold them in trail all is level. Release the stick and the right aileron comes up about 1/8". Any suggestions appreciated. Haven't looked into it much at this point as it is only a minor bother. Have more fuel in the left wing and all is fine.
Landings are a piece of cake. Just don't want to get too fast at any point in the pattern. It really doesn't slow down as easily as the spam cans I am used to. I am holding 65mph on final and will work down a bit more as experience dictates.
I am going to get some speed/climb figures before I swap to the E-mag. Also firm temps. I am videotaping the panel and find that the easiest way to get the data down. I hope to be able to give good before/after comparisons. Oh, yes. Think I may have to replumb the fuel flow sensor as it seems a little iffy. It is hooked to the AF2500 engine monitor.
All in all, I couldn't be happier. Who am I kidding, I didn't win the lottery. Anyway, this is one great airplane.
Bob Kelly
Bob Kelly
