Infinity Stick/Relays/Terminal Strips
Mark L
Member
For 7A builders with infinity grips; where are you locating relays and terminal strips? I have seen where one 8 builder brought the wires from the stick all the way to behind the panel to a terminal strip. Where is the best place to bring the blue wire bundle out of the RV-7_ stick?
Pictures greatly appreciated.
Pics from my Infinity Grips/ RV-7
Enough said!
Hi Mark, I used angles and mounted the board and terminal strips between the ribs under the pilot seat. I drilled a hole in the stick near it's pivot point, put a plastic bushing in the hole and pulled the cable thru to hook up to the terminal strips. Works great.
Danny
RV-7A
Nice work Scott!!!
I also put strips on the floor so I could get at them later without having to use a stubby screwdriver.
- Peter
