Hello All
I will be installing an Infinity Stick Grip in my RV-4 over the winter and I have a few questions for the ones of you who have done the same thing before...
1.- Did you have to cut the stick so that the Infinity grip did not hit the panel versus the standard Vans stick grip?? ( My panel is 3/4'' lower than standard )
2.-Where did you guys run the wire bundle.....Inside the stick or on the outside ???
If on the inside did you have to re-inforce the stick after drilling an exit hole for the wires??
3.- Did you have to cut the slot as per the Infinity instructions if running the wires inside the stick??
Thank you for your feedbacks..
Bruno
[email protected]
P.S: If any of you have pictures of your install, I'll be glad to look at them if you don't mind sending me some...![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Bruno
[email protected]
