I have a -7 with about 60 hours on it. The flap behaviour today has me scratching my head. I thought I had a flap failure in flight but after looking at the uploaded flight data on Savvy, I see that
- the first in-flight extension (and subsequent retraction) was normal
- the second in-flight extension went to about 88% of normal. Retraction normal.
- the third extension went to about 5% of normal. This is what I identified as a failure.
After landing, powering down and powering up, the flaps worked normally through several cycles on the ground. I wanted to believe that the power cycle had solved the problem so I went for another quick flight. On that flight, the flaps extended to about 12% of normal. Post-flight they again worked fine on the ground.
The flaps are controlled by an Advanced ACM.
Any ideas?
BTW, the flap actuators from Van's are $695 and on back order so that won't be my preferred option.
Any ideas?
